muchas  gracias por la ayuda ,
descarga el drive de video de la pagina de biostar-usa.com  , al tratar de instalar el drive sale este  cartel :
que dice  que consulte el archivo de poseso ..etc ....y se suspende la instalación .
=========== S3SETUP LOG FILE - Started at 23:48:41 on 3-7-2001 ===========
S3Setup v1.00.16-JV (1.01.06) on Win XP
  bAllowReboot: TRUE
  bSilentReboot: TRUE
  bPromptReboot: TRUE
  bPromptSilentReboot: FALSE
  VendorID to find:5333
INF File Located at: C:\Documents and Settings\Administrador\Escritorio\vga\ps5333.inf
Found - ven:5333 dev:8A26 ss_dev:8A26 ss_ven:5333 rev:00 bus:01 devnum:00 func:00  (inVGA=1)
Enumerating Display class devices...
  No more displays.
Could not find an enumerate device to match hardware.
Enumerating all Enum\PCI registry entries...
  Device #0 subkey: 'VEN_1106&DEV_0305&SUBSYS_00000000&REV_81'
  Device #1 subkey: 'VEN_1106&DEV_0571&SUBSYS_05711106&REV_10'
  Device #2 subkey: 'VEN_1106&DEV_0571&SUBSYS_05711849&REV_06'
  Device #3 subkey: 'VEN_1106&DEV_0686&SUBSYS_00000000&REV_22'
  Device #4 subkey: 'VEN_1106&DEV_0686&SUBSYS_00000000&REV_40'
  Device #5 subkey: 'VEN_1106&DEV_3038&SUBSYS_12340925&REV_10'
  Device #6 subkey: 'VEN_1106&DEV_3038&SUBSYS_12340925&REV_1A'
  Device #7 subkey: 'VEN_1106&DEV_3038&SUBSYS_30381106&REV_62'
  Device #8 subkey: 'VEN_1106&DEV_3057&SUBSYS_30571106&REV_30'
  Device #9 subkey: 'VEN_1106&DEV_3057&SUBSYS_30571106&REV_40'
  Device #10 subkey: 'VEN_1106&DEV_3058&SUBSYS_41611106&REV_50'
  Device #11 subkey: 'VEN_1106&DEV_3058&SUBSYS_760015DD&REV_20'
  Device #12 subkey: 'VEN_1106&DEV_3068&SUBSYS_4C211543&REV_30'
  Device #13 subkey: 'VEN_1106&DEV_3104&SUBSYS_31041106&REV_65'
  Device #14 subkey: 'VEN_1106&DEV_3106&SUBSYS_30651106&REV_8B'
  Device #15 subkey: 'VEN_1106&DEV_8305&SUBSYS_00000000&REV_00'
  Device #16 subkey: 'VEN_11D4&DEV_1805&SUBSYS_180511D4&REV_00'
  Device #17 subkey: 'VEN_13F0&DEV_0200&SUBSYS_020113F0&REV_31'
  Device #18 subkey: 'VEN_5333&DEV_8A26&SUBSYS_8A265333&REV_00'
    Found matching hardware.
Found InstID=PCI\VEN_5333&DEV_8A26&SUBSYS_8A265333&REV_00\4&9aeded5&0&0008.
Found Mfg line: "S3.Mfg".
Description="S3 Graphics ProSavageDDR = S3Psddr, PCI\VEN_5333&DEV_8D04".
Cannot find compatible device for VEN_5333&DEV_8A26 in C:\Documents and Settings\Administrador\Escritorio\vga\ps5333.inf.
DestroyTimerWindow returned an error!
-> El programa de instalación no pudo completar la instalación.  Para obtener más detalles, consulte el archivo de progreso en el directorio de Windows.
También lo descague con el Driver Genius y es lo mismo sale el mismo cartel..
¿cual puede ser el problema ?
