Hola Manuel oaso a detallarte
Standby,
luego ---> Mute > 2 > 7 > 9 > Power on
MENU FUNCTION OSD DISPLAY RANGE INITIAL DATA
D
E
F
S-CORRECTION SC 0 ~ 15 STEP 8
VERTICAL AMPLITUDE VA 0 ~ 63 STEP 19
VERTICAL SHIFT VSH 0 ~ 7 STEP 5
VERTICAL LINEARITY VL 0 ~ 15 STEP 10
HORIZONTAL SHIFT HSH 0 ~ 31 STEP 13
C
R
T RED CUT-OFF RDC 0 ~ 255 STEP 124
GREEN CUT-OFF GDC 0 ~ 255 STEP 88
BLUE CUT-OFF BDC 0 ~ 255 STEP 121
GREEN DRIVE GAIN GDRV 0 ~ 127 STEP 55
BLUE DRIVE GAIN BDRV 0 ~ 127 STEP 60
DISABLE VERTICAL OUTPUT VSD Off-On Off (0)
P
I
C
T
U
R
E AUTO GAIN CONTROL AGC 0 ~ 63 STEP 40
IF FREQUENCY SELECTION TIF 0 ~ 7 STEP 1
SUB BRIGHT SBRT 0 ~ 31 STEP 7
SUB CONTRAST SCON 0 ~ 15 STEP 10
SUB COLOR SCOL 0 ~ 31 STEP 0
SUB TINT STIN 0 ~ 31 STEP 0
NTSC SUB COLOR SNCL 0 ~ 31 STEP 0
SUB SHARPNESS SSHR 0 ~ 31 STEP 10
SHOOT SYMETRIC ASSH 0 ~ 7 STEP 0
ZOOM CONTROL ZOOM 0 ~ 31 STEP 10
WIDE (16:9) CONTROL WIDE 0 ~ 31 STEP 10
UV CONVERTER UVC 0 ~ 7 STEP 3
Y DELAY Y DL 0 ~ 7 STEP 7
Y GAMMA Y GA 0 ~ 3 STEP 1
BLACK STRETCH B ST 0 ~ 3 STEP 2
PEAK WHITE LIMIT YPL Off-On On (1)
ABL GAIN ABL 0~3 2
O
S
D ON SCREEN LEVEL OSDL 0 ~ 3 STEP 2
ON SCREEN ABCL OSDA Off-On On (0)
ON SCREEN H-SIZE OSDF 0 ~ 105 STEP 70
ON SCREEN H POSITION OSDH 0 ~ 31 STEP 10
ON SCREEN V-POSITION OSDV 0 ~ 31 STEP 21
BUS STOP BUS Off-On Off (0)
S
O
U
N
D FM PRESCALE ( RF) FM-P 0 ~ 128 20
SCART PRESCALE (AV) SC-P 0 ~ 128 12
SCART 1 OUTPUT VOLUME SC-O 0 ~ 128 123
VOLUME CURVE V01 0 ~ 127 20 / 070
VOLUME CURVE V15 0 ~ 127 55 / 100
VOLUME CURVE V30 0 ~ 127 68 / 108
VOLUME CURVE V50 0 ~ 127 80 / 117
Suerte Batuque presidente de planetatecnico
